Traveler7's avatar
Traveler7
Advice on controlling Alternator to House battery charging?
Thanks in advance for your help!
I have a 60 amp alternator in my 1977 Dodge Camper Van and i want to use it to supplement a Solar setup- 160 watt panel flat mounted on roof with a 10 amp PWM solar controller feeding a 100 or 120 AH AGM battery.
Currently (no pun intended) there is a diode battery isolator running power to charge the house, but I want to be sure it does not overcharge the AGM. My thought is to get a 30 amp PWM solar controller and run thru it so I get an automatic float mode out of it.
I know a 60 Amp alternator probably won't send much back at all, but I am concerned that running many hours every day may cause a problem. I'm also open to eventually upgrading to a 110 Amp Alternator in the future.
So........?
Thanks again!
