chuck3's avatar
chuck3
Advice on Lithium Solar setup
Hello,
I'm about to move into a conversion van full-time, 80% boondocking, and would like your advice about what I'm planning. My electrical requirements won't be much. I don't expect to use more than 400 AC watts or it's DC equivalent at any one time, and normal usage will be less than 200 AC watts or it's DC equivalent for 9 hours a day.
Currently I have 2 x 100w flexible solar panels and a 600w pure sine inverter.
I'm planning on getting a 100ah lithium (LiFePO4) battery ( https://battlebornbatteries.com/shop/12v-lifepo4-deep-cycle-battery/) and a solar MPPT charge controller for it (probably https://www.amazon.com/Victron-SmartSolar-Charge-Controller-Bluetooth/dp/B073ZJ3L13). A big reason that I'd like a lithium battery is because I will occasionally want to bring it with me to a friend's house to charge it from the wall, and 30 pounds in a backpack allows that.
Here are my biggest questions: how will I know when the lithium battery is fully charged, and how will I know how much capacity is used or remaining? With lead batteries it's fairly simple because the volts indicate remaining capacity, but from my understanding, lithium's voltage doesn't change much between it's full and empty states (I could be wrong here).
  • Almot's avatar
    Almot
    Explorer III
    2oldman wrote:
    Actually, with mine there is quite a difference in its resting vs bulk/float voltage.
    Because when it drops to 13x, it is not charging anymore, basically the same as pulling the plug off.
    OTH, bulk charging is 14x. Bringing it all the way up to manufacture specked maximum is wrong, it is not supposed to be fully charged every time, but I won't go there now.
  • The manual for your battery says the bulk voltage is 14.2v-14.6v. When that drops it should be fully charged.
    I was surprised to see there's an absorb phase. Most Li's I've seen don't have that. I hope the battery is better quality than the grammar in that manual.
    As for what's used, you'll need an ah meter for that.
  • Almot's avatar
    Almot
    Explorer III
    You need AH meter, a.k.a. battery monitor, not cheap ~$170 and it won't help when you take the battery away for charging. Even with flooded/led battery you can't effectively estimate the remaining charge by looking at the voltage, other than early morning with loads off and before solar starts.
    Ebay had some $40 re-settable AH meters, maybe somebody will provide a link.
    If not a monitor, then get LifeBlue Battery, it comes with Bluetooth monitoring, i.e. the "monitor" chip is mounted in the battery case. 2 pounds lighter than Battleborn 100AH. Can't say anything good or bad about either brand.
