chuck3
Jan 26, 2018Explorer
Advice on Lithium Solar setup
Hello,
I'm about to move into a conversion van full-time, 80% boondocking, and would like your advice about what I'm planning. My electrical requirements won't be much. I don't expect to use more than 400 AC watts or it's DC equivalent at any one time, and normal usage will be less than 200 AC watts or it's DC equivalent for 9 hours a day.
Currently I have 2 x 100w flexible solar panels and a 600w pure sine inverter.
I'm planning on getting a 100ah lithium (LiFePO4) battery ( https://battlebornbatteries.com/shop/12v-lifepo4-deep-cycle-battery/) and a solar MPPT charge controller for it (probably https://www.amazon.com/Victron-SmartSolar-Charge-Controller-Bluetooth/dp/B073ZJ3L13). A big reason that I'd like a lithium battery is because I will occasionally want to bring it with me to a friend's house to charge it from the wall, and 30 pounds in a backpack allows that.
Here are my biggest questions: how will I know when the lithium battery is fully charged, and how will I know how much capacity is used or remaining? With lead batteries it's fairly simple because the volts indicate remaining capacity, but from my understanding, lithium's voltage doesn't change much between it's full and empty states (I could be wrong here).
