wa8yxm
Jun 05, 2013Explorer III
In electricity there are two terms one of which is misused and the other underused.
Surge and spike
Now that Joule rating is about SPIKE supression.. A spike is a very short voltage peak lasting (usually) less than 1/100th of a second.
A surge, on the other hand, is a wave, can last for seconds and if one hits those spike supressors sound quite a bit like firecrackers as they blow up. I know, I was there when it happened (my basement when the power company screwed up)
More Joules are better.. but in the event of a genuine surge (or for that matter a "Dip" in voltage lasting more than a fraction of a second) that power line protective device simply cuts you off, as well it should, to protect you.
They monitor voltage, may monitor frequency and waveform and cut you off if the monitored values are not proper.
Surge and spike
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
