LifeInsideJack
Feb 24, 2017Explorer
hypoxia wrote:
I just use Strong Ties type L brackets. Cheap & available at Lowes, HD, Menards etc.. Home made are fine also, not rocket science.
Your speed isn't that important, you may be driving into a 50 knot headwind so not a good idea to mount them vertically.:B
That's a good point. I found some less expensive brackets online so I ordered them up. The roof is that typical plywood with snow coat on it. Nothing really sexy.
What I think I might do is screw these down into the roof, seal them up real good and then cable strap them to the A/C unit. This way should something want to get loose it will won't leave the coach. I'm certain I'd hear something if it even started to go loose but I never want to risk a lawsuit.
IT seems that solar is still a "new thing" and there isn't much of a standard on it yet. I'll photo up what I have when it's finished.
Thanks,
