Almot
Mar 10, 2017Explorer III
RJ, to be able to remove this thumb drive (or a regular bolt), there has to be a thread in the frame. I installed rivet-nuts into the frame, for this purpose. Stainless rivet-nut. The idea was to tilt the panel sometimes. Having abandoned this idea (too much trouble and there is no need to tilt, I harvest enough power already), if I were to do it again, I would rather used Z-brackets and avoided the rivet-nuts.
Unless you can get somehow into that 1" crack under the panel and attach/remove a regular lock-nut on the other side.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
