precioustime's avatar
precioustime
Explorer II
Feb 27, 2016
Advise on Surge Protectors?
I have a 2016 Fleetwood Storm 28MS that uses 30 amp shore power. I have never had a surge protector on my other coaches and never had any problems. What is the minimum surge protector I should have? Any particular brand? Will the lowest price surge protector do the job?
  • Steer clear of the lowest price surge protectors as they won't offer the addtional features of the higher priced units, most particularly protection from excessively low campground voltage which is not uncommon at all. The two leading brands are TRC (Technology Research) and Progressive Industries ... I've owned both brands but many if not most on the forums would give the nod to the Progressive units because they carry a lifetime warranty. Their EMS units are available as both portable or hard wire ... I chose the hard wire but many prefer the portable because it's so easy to use - just plug it into the campsite power post and plug the trailer's main service cable into it. Since your trailer is wired with 30 amp main service the Progressive portable unit EMS-PT30C would be an excellent choice. Some do nevertheless choose the 50 amp version which will also work just fine with 30 amp service as it can later be used if they upgrade to another rig that's wired with 50 amp service. Personally I'd buy the 30 amp model for your current trailer as used Progressive EMS units priced correctly are easy to sell, allowing you to then buy a new 50 amp version when you upgrade to a different rig that requires it.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
