bobsallyh
Apr 02, 2016Explorer II
Just beware that E-Z Lube will let grease and the separated oil past the inner seal, then it coats the brake shoes and magnets. Bought a new fiver that has E-Z lubes on. After several years of use I took a hub off to check. Well there was so much grease in the hub from Dexter that it pushed thru, now remember there was never a grease gun on this trailer. Disassembled everything, cleaned up the Dexter cluster, and went old school, packed the bearings myself. And I have seen other E-Z Lube hubs in the same condition. It is a marketing ploy on the RV manufactures and dealers to make it "look easy". IMHO
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
