BB_TX
Apr 02, 2016Nomad
The EZ Lube do work as advertised when done properly, that is pump slowly, do not force it, keep the wheels turning constantly while pumping, and the grease will flow thru the inner bearing, thru the hub center, and out thru the outer bearing. It is, and should be, a fairly slow process. Don't rush it, don't force it. I think the mistake people make is getting impatient, in a hurry, and over pressurizing the pumping action. I have done mine several times and no grease past the rear seal.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
