westend
Apr 02, 2016Explorer
tragusa3 wrote:
Alright...I've heard enough. You have all swayed me back the other way. I'm going to hand pack. As stated, don't trust the factory work. I need to pull open and inspect the rear seals and brakes anyway.
I can to the job myself, the only part I'm hesitant of is popping the rear seal out. I don't have a tool for that. I did see a guy on youtube made one of PVC parts.
Good call. You don't know what is going on inside the drum/hub until it's disassembled. I don't trust factory work either, been burned too many times.
Getting the seal out isn't problematic. Seating the new seal correctly can be. I'd suggest to buy a seal driver set or make a tool if the trailer bearing is the only one you'll ever service.
For those wondering why their auto bearings don't need service like a trailer bearing--The auto bearing is typically a sealed cartridge style, unlike a trailer bearing. They are manufactured to a tighter tolerance and durability, besides being totally sealed.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
