LarryJM
Apr 02, 2016Explorer II
3oaks wrote:midnightsadie wrote:Correct. In theory, Dexter's easy lube system should work great. However, when you pump the cavity between the inner and out bearings full of grease there is no room for expansion and it makes for grease churning which in itself causes heat. The thinned grease is then forced passed the bearing seal and contaminates the entire brake shoe assembly.
IF you pump to much grease in it will push past the seal and ruin your brakes, this is what a lot of people do, in this case more is not better. dexters work great if used right. if you pack the cavite full it,ll expand and ruin your brakes
ABSOLUTELY WRONG!, If you don't fill the cavity completely with grease you will not get new grease to the outer bearing. Also, you expansion theory is baloney since excess grease from expansion if there is any and that I doubt will simply exit around the outer bearing just like the EZ-lube system is designed to work.
Folks that don't understand these systems should stay away from grasping at phantom straws and putting out INCORRECT and MISLEADING INFORMATION.
Larry
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
