full-timer
Apr 03, 2016Explorer
MEXICOWANDERER
Mexicowanderer, boy you must be an old timer talking about Timken roller bearings and Chicago Rawhide seals changed out many of those.
If a bearing that needs greasing is a bearing that needs to be checked. I've hand packed many of those bearings, grease-turn a little-grease turn a little is the way to go. If you install the two lip seal make sure the seal is turned the right way.
Joe
Joe
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
