jake2250
Apr 04, 2016Explorer
Ha Ha, Spend the money on Dexter axles and NOT use the Easy Lube you bought!! Ok,, I bought a four year old trailer, Couldn't get a straight answer if the previous owner repacked them.
So, I pulled all four and re sealed and repacked,,a dirty smelly back hurting job!!
It has Dexter easy Lube,, I have purchased good wheel bearing grease and use the axles as they were intended,, Works good been six years and all four wheels rotate as they should,, I often check wheel and hub temp on long trips,, Nothing wrong yet!! Also,, to not "Over Pack" I run my pinkie finger in there and remove grease back to the packing washer.. Thus giving expansion room,, Or as I call it,,Slinging room!! Also!!! Replace those rubber caps after a few years,, they leak!!
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
