Huntindog
May 18, 2016Explorer
The easy lube system may have another serious flaw.
Some years ago a member here on the forum (maybe jbarca?) posted why he felt so many had problems with grease getting past the seals. It seems that the grease hole had a sharp edge, that often damaged the seal when the drum slid over it during installation. His solution was to take a Dremel and chamfer that edge.
I have not taken mine apart yet to see if this is a problem... But I kinda doubt that the factory is chamfering this edge. When I do get around to it, I will chamfer this edge if needed.
Whether you use the easy lube feature or not, a seal that is damaged in this manner is not a good thing. Naturally if a seal is damaged, pumping grease into the hub would be a really, really, bad thing
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
