howardwheeler
Feb 19, 2014Explorer
The motor is the cylindrical white part that sticks off the end of the housing I've detached from the roller tube. I've drilled out the rivets and got that motor housing loose from the tube. I'm afraid to pull the motor assembly farther away from the tube because I don't know what that axle is inside the tube. There is some kind of tension that pulls on that axle.. I can overcome the tension. It's not real strong, but it can pull the whole assembly back up toward the trailer.
