- ksg5000Explorer IIIf your looking for something simple and inexpensive you can use a plug-in voltmeter combined with one of the battery tables already posted. I keep something similar plugged in all the time so I can monitor my converter -- rig needs to be disconnected and battery rested b4 trying to measure status of batteries.
- AlmotExplorer III
2oldman wrote:
It's close enough.
Marginally better than OEM panel with indicators Full/Empty for black tank and batteries.
What he wants - handheld digital SOC meter - doesn't exist, except for once a day with a rested battery. - MrWizardModeratorthere is no hand held soc meter, except a hydrometer
you need a meter mounted inline, that counts the amp hours
you fully charge the batteries to the point that they are accepting less than 1 amp per battery at 14.8v,
now fully charged you program the meter with the total ampHr capacity of the bank
now that meter will display the SOC by counting ampHrs in / out and compute the percentage - red31Explorerget a meter that reads 75% all the time. a little test done by BFL shows 65%-100% when the voltage is 14.4v!
- 2oldmanExplorer II
Almot wrote:
It's close enough.
Voltmeter for SOC is like a broken clock that is right twice a day.. - AlmotExplorer IIIWhat red31 said.
With voltmeter it will be only once a day, - after 12 hours rest. - red31Explorer
dtappy3353 wrote:
Looking for a hand held battery tester which give volts and "state of charge".
Accurate SoC:
While being discharged at some unknown rate?
While being charged at some unknown rate? - AlmotExplorer III
dtappy3353 wrote:
Thank you very much for the charts...they are the paper version of what I'm seeking.
Handhelds are for checking things occasionally, when you suspect that something could be wrong. Get a reliable multimeter to measure volts and consult the chart. It will tell the correct charge only after battery had rested 12-24 hours. You need a good multimeter anyway.
Voltage by itself is a very approximate measure of charge, cheap digital voltmeters are often inaccurate, the net result might be no better than OEM lights panel Full/Half/Empty. If it reads both volts and % of charge, then both volts and % will be inaccurate, be it a handheld or permanently installed.
For accurate on-the-go data, install battery monitors like those in Time2roll links. They measure not just volts, but also amper-hours in and out, and calculate the remaining charge.
If money is a problem, here is a cheaper device for the same purpose: Drok AH meter. Reads volts, remaining AH, and % of charge. Drok is more-less known brand. Ebay sell knock-offs that look similar, can't comment on those. - Sam_SpadeExplorer
Don't make this harder than it IS.
Just print out a half dozen copies of that chart in the previous post, buy yourself an inexpensive digital multi-meter or two......and you are done. - Ski_Pro_3ExplorerI bought one of these;
https://www.ebay.com/itm/DC-Battery-120V-300A-LCD-Voltage-Current-Watt-Power-capacit-Digital-Combo-Meter/162144298635?hash=item25c08da68b:m:msNz_Ko6X9OlmwwnCn2IGLQ
A little thinking to set up, but man, it will tell you everything you need to know on the state of charge for the battery and it's over all condition.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
