dtappy3353's avatar
dtappy3353
affordable battery tester
I understand percentage better than volts. Is there a battery tester that gives you percentage to help me understand the available charge of my batteries on Fiver.
  • Thanks for the quick responses. Thank you very much for the charts...they are the paper version of what I'm seeking.
    Looking for a hand held battery tester which give volts and "state of charge".
    Do you want to test for diminished total capacity?
    Or do you want to monitor the existing charge level?
    For diminished capacity you may need a load tester to be used in conjunction with a hydrometer.
    If you want a monitor to show a percentage of remaining charge there are many available for about $200+. Victron and Trimetric are two of the popular brands.
    http://www.bestconverter.com/TriMetric-Battery-Monitor
    http://shop.pkys.com/Victron-Energy-BMV700-Precision-Battery-Monitor
  • What's the problem with voltage? It's a common and reliable indication of remaining capacity on LA batteries. I would think a battery tester (not a hydrometer) would use voltage.
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 20, 2025
