mikeinidaho's avatar
mikeinidaho
Solved
AG battery switchover
2015 Itaca Sunstar.  Will the converter charge AG batteries without any problems? I need to change out my old batteries and want to upgrade to AG's.
  • Depends on your converter. Most made within the past 10 years will work with AGM batts. Check the type you have and check the compatibility or if there is a setting for different battery types.
  • Presume you mean AGM. Also presume you’re not looking for advice and haven’t even seen what Charger/converter you have nor looked up the specs on it.
    We can’t see into your camper from the internet.  And you have to answer your own question since you didn’t provide enough info for us to do your research for you.
    • StirCrazy's avatar
      StirCrazy
      Moderator
      is agm still a thing?  I would have thought people quite spending the extra money on thoes years ago.
      • way2roll's avatar
        way2roll
        Trailblazer
        Dunno, but that wasn't really the OP's question.
