Naio's avatar
Naio
Explorer II
Jun 04, 2017
AGM 11.06v after charging. Hopeless?
This is about my old house battery, not the Fiamms nor the MK gels in my ice machine.
I've been suspicious of this battery for a while, but have not used it much and had other things to worry about. I just kept topping it off.
Finally got around to testing it. It went to 13.36 at the terminals while on the charger, but after I let it set for 2 hours it dropped to 11.06. It was 10.something before I charged it and I suspect that is its true resting voltage.
Am I correct that this means it has a bad cell and there is nothing I can do? I like to run things by you guys before I do something like recycle big azz battery :B.
Spec sheet pdf.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
