dave17352's avatar
dave17352
AGM batteries vs flooded wet cell deep cylce
Well I was just curious about people that have used the agm sealed batteries. Whether you feel they are better and worth the extra cost. Also about the longevity vs regular deep cycle batteries. I see sams club has the energizer 100 amp hour agm for about $170.00. Its suppose to last twice as long, twice as many cycles and have a safe deeper discharge, like 6o percent instead of 50 percent. Also no maintenance. I am going to be upgrading my batteries and I am looking at golf cart vs 12v deep cycle vs 12v agm. All opinions appreciated!
Thanks
  • Optima Blue Tops
    This was one of the first companies making this type of battery and the Blue is specifically made for marine/Rv use as opposed to a battery designed for cranking amps.
  • Sears AGM Group 31
    These are the batteries that I have and I have zero trouble with them. I didn't want to have to fiddle with adding water to batteries and equalizing them, etc. 1150 CCA is pretty good (not saying that CCA's mean hoot in camping)
    I also have a Sears Platinum AGM Battery in my Truck which had performed flawlessly!
    Personally, I'd stick with the Sears as opposed to the Energizer. The Sears has a tremendous warranty (4 years/return iirc)
    WoodGlue
  • Which brings up another question, are Sears Group 31 12v agm better than Energizer 12v agms or are they really the same. The energizer is made by Johnson controls. I think
  • I am going on 5 yrs with a single Sears Group 31 12V AGM and it still holds a good charge, able to run the furnace on cold nights while boondocking. The money spent was worth it not to deal with adding water and the acid a wet cell emits, already had to rebuild a battery compartment due to acid and I thought I was doing a good job. No more wet cells for me. I use a Honda 2000 for recharging during the evening while watching tv.
