socal
Jan 20, 2014Explorer
AGM batteries
Hello, wondering if AGM batteries should be equalized monthly as normal wet cell batteries are. Thinking of changing to AGM. Thanks
Socal
Socal
mena661 wrote:beemerphile1 wrote:AGM still has electrolyte.
Maybe I don't understand the term equalize? I thought equalize is the stirring of the electrolyte. Since neither AGM or gel have electrolyte (liquid), how would equalizing be beneficial?
red31 wrote:This is equalizing.
I thought equalize meant to make equal when different cells were unequal, uneven sulfate.
Almot wrote:Confusing to me also. MEX says they can all use Lifeline's EQ/conditioning routine but not all will say you can. What makes Trojan so different than Lifeline or Deka. It's all basically the same construction and chemistry. Or maybe it isn't??
Puzzles me.
The big question remains - WHEN. Lifeline manual officially says - when 20% capacity has been lost. Lifeline engineers in that sailor's blog that you must remember, unofficially said to equalize once a month if you don't charge them fully every time, otherwise the lifespan shortens a lot.
Other manufacturers simply don't say anything on the subject.
Oh well, is it another endless debate coming?
mena661 wrote:
Deka lists an equalizing voltage but no instructions that I can find on when to perform that procedure.
Almot wrote:Deka lists an equalizing voltage but no instructions that I can find on when to perform that procedure. I'd go with what MEX says on that.
Only Lifeline aka Concord has recommendations and instructions on how and when to equalize their AGM - they call it "conditioning".
