brulaz
Apr 28, 2018Explorer
WRT the Magnum inverter/charger and BMK+shunt:
Apparently Magnum's MPPT solar charger can be networked in along with the BMK+shunt and ARC (advanced remote control). It can be controlled by the ARC and inverter/charger settings so the BMK's estimate of battery SOC can be used to terminate absorb from solar charging as well as from shorepower charging.
But if instead you use a NON-Magnum, NON-networked solar charger, things might go awry with the Magnum's logic?
Pretty complicated networked system:
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
