pianotuna
Apr 28, 2018Nomad III
Hi,
I unplugged the RV, turned off all loads (master disconnect switch). Blue Sky showing 1.7 amps for 556 amp-hours of battery bank in float.
MrWizard wrote:
To know the amps charger into the battery
Install a separate amp meter for the battery,
Or
Turn off all 12dc loads, lights, water pump etc.. Turn off any stand alone inverter, except the fridge parasitic control
And see what your Magnum displays says
The low milliamp draw of the fridge will be negligbile
The display will reflect the charge amps
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
