Almot wrote:
smkettner wrote:
I would charge and float at the lower end of specification.
Transition at 2 to 5 amps.
Transition to Float - I read about 1% of capacity, so it's 1A for 100 AH battery. 2-5 A = lower transition SOC, (70% ??), and my gut feeling is that this is better for battery. Might take too long to charge fully. Will see.
"Lower end of specs" - UPG table suggests 14.7 at 77F, and at the same time allows 14.4 to 15V. This is not a temperature range, but allowed range at 77F. Weird...
Though, Deka specs aren't too accurate either, in the range 70-80F it's 14.3 optimum and 14.6 max, no telling what is the "minimum" - makes me think that at 77F it should be 14.3 or less.
No, Deka's specs are exact.
Page 5, Appendix A.
Charging rates are discussed in detail on Page 3.
HTH;
John
