Ok, from the Lifeline manual - I like collecting useless things ;):
For repetitive deep cycling, chargers should have an output current of at least 0.2C (20 Amps for a 100 Ah battery). If the output current is less than this value, the cycle life of the battery may be negatively affected.
Due to the low impedance design, Lifeline® batteries can tolerate in-rush current levels as high as 5C (500A for a 100Ah battery).
So there are limits even for Lifeline. Pretty high lower "limit", in particular. To achieve their famous longevity, you need minimum 20A per 100 AH battery - very few solar users will have that much. Note that upper limit 5C (I was wrong, it's 5C not 4C) is called "in-rush current level". They don't comment further on 5C, but sounds to me like meant for occasional faster than normal charging.
