jrnymn7's avatar
jrnymn7
AGM Charge Rates and Times
I am interested in knowing how fast AGM deep cycle batteries charge, especially in the upper SOC range.
Things to consider:
- Ah Capacity of battery/bank
- starting SOC or DOD, or Ah's consumed/replaced
- Charge Rate, expressed as C/? (Battery Capacity divided by charging amps... i.e; 400Ah/100a = C/4 rate)
- At what point do amps begin to taper?
- Charge time
Thanks for any input you can offer.
  • I run 150 amps into my 3@85AH batteries. My batteries are rated for C5 charge rate - 1250+ amps. The charger starts tapering within minutes, but that is from 150 amps, they are still pulling 80-120 for quite a while. I would *guess* a 50-90 takes an hour to an hour and a half - ~125ah. I am getting solar this spring to attempt the 90-100 without running the genset.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Xantrex, for "Generic AGM" shows more or less the same charge rates as flooded wet cells (I think .1 or .01 volt diference is all).
    LIFELINE, is the only company I have seen suggesting different (higher) rates.
    And even Lifeline says the Charge Wizard does a good job. So...
    (This is part of the reason I am a long way from sold on AGMs... There are other reasons as well)
  • We looked at this some time ago and the results were that with the same charger both acted pretty much the same for charging profile, time to do a 50-90, when they taper, etc.
    What is not addressed in that is how much more of a charging rate the AGMs could take if they had a different charger on them. With that it gets confusing because it seems different brands or styles of AGM are specified to do more or less than other AGMs
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
