BFL13
Sep 25, 2019Explorer II
MEXICOWANDERER wrote:
Socket-too em, BFL!
Charge Steady 15 amps EACH until voltage rises to 16.2 volts then quit. Way way way (Enough 'way's'?) below venting pressure to forget about it...
I can bring each one to 16.2v with my PowerMax (will do up to 16.5 constant voltage), but amps will taper of course.
I just can't figure out how to implement your light bulb trick with the equipment I have in order to achieve constant amps. You have explained it several times, so regard me as hopeless.
Is there any point in doing it to 16.2v with tapering amps?
