BFL13
Sep 29, 2019Explorer II
Here is something on full_mosey's AGM:
https://www.osibatteries.com/p-28573-eaton-powerware-pwhr12500w4fr-battery-12v-vrla.aspx
Thanks LY, I will check that out. When I split the bank I can only have the Trimetric on one of the sets at a time, so having the ammeter on the second charger (converter rigged as a portable charger) would be handy for sure if doing two sets at once to speed things up.
I have never understood why they don't put an ammeter on converters same as they have on any portable charger. How hard can it be?
I will be able to use the Trimetric when finishing up the second 27 today, now the Tri is freed up from doing for the other batts. That will show the amps when using the converter at 16 volts after the VEC is done at its 15.8. (the VEC has its own ammeter)
The VEC is down to less than 4 amps when it gets to 15.8, so it won't likely be many amps getting to 16. Find out later today.
