Should my battery read 12.41v under load when it is basically fully charged? Backstory: I saw that I'd accidentally bumped the switch on my inverter. Not knowing how long it had been on, I put a vo...
Ignore the battery chart that was posted as that is for flooded lead acid technology.
An AGM may only be about 60% charged with a 12.6 resting Voltage. A 100% charged AGM is above 12.8 for sure and many, if not most, AGMs rest at 13 or above Volts.
HTH; John
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
