Should my battery read 12.41v under load when it is basically fully charged? Backstory: I saw that I'd accidentally bumped the switch on my inverter. Not knowing how long it had been on, I put a vo...
It depends which AGM you have. For example mine are surplus acid so 50% is as deep as I wish to go. Starved acid run out of "working fluid" before discharging too far--but I'd still avoid "crashing" them.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
