time2roll wrote:
Alarm is annoying but would not cause me to stop. Low voltage cut-off is the important point to note. And yes AGM might hang in a bit longer. However at that point I would wish I had just started a bit sooner with propane.
The idea is that at 6am while you are making toast, your park neighbours will hear that alarm, the dogs will start barking, and chaos will ensue. Otherwise later in the day the noise doesn't matter and you can keep going till the job is done as long as the inverter stays above its shut-off voltage.
---Full Mosey is the man when it comes to AGMs as far as I am concerned! Got me onto it eventually. :)
