dougrainer
Jul 17, 2014Nomad
1. Wall tstat systems CANNOT freeze up regardless of fan setting---They have a freeze sensor that prevents that
2. Usually, on a wall tstat system if on Auto(Hi) the fan will run on high until it reaches within 5 degrees of the set temp then go to lo fan until it reaches the set temp and then the fan and compressor go off. When the tstat calls for cool again, it will go to lo fan first as long as the inside temp is within that 5 degrees of set temp. Doug
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
