joem789
Jul 25, 2017Explorer
Sorry. I neglected to mention I run the fridge with propane. We boondock. So using the heating element is usually out of the question. But I did run the generator to try using electric to see if it acted any better. But it was actually worse. I think the element might have been giving problems a couple years ago during last time I used it. But became a non-issue with using propane ever since.
I am only just now seeing this issue. The door seals are like new. And seal up nice and tight all way around. Although. If they were an issue, they never stopped the fridge/freezer from doing its job. I don't think they apply in this case. The problem seems to stem from the back of the fridge.
The late afternoons/evenings are the time of day when the doors are typically opened and closed numerous times with the family being home. Right now the fridge thermistor reads 33. Mid 30s is typical this time of night. Leaving the door shut overnight, itll get down to around 26 reading. Normally everything in the fridge would be frozen by morning at a setting of 9. But that won't be the case. I can put a jug of water in the freezer and it takes 2 days to begin to freeze. Whereas, before. It would freeze overnight.
From the way I understand it. The fridge fins work off the freezer. So I am thinking the freezer just isn't operating as cold as it should. SO what would cause that to happen? I think my Norcold is a 62x 2-way model.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
