wa8yxm
Jul 26, 2017Explorer III
37 for a fridge is considered NORMAL it may be coincidence the temps you see.
HOwever as for the freezer. I see one of the responses says the freezer gets "Warmer" when A/C is running... this may be because the temp sensor in the fridge is IN THE FRIDGE, not the freezer.. The manufacturer assumes a relationship between the fridge and freezer and designs it so that percentage of cooling goes to each part.. If it is warmer out or in this specific warmer INdoors the fridge heats faster and the cooling system runs more... The freezer gets colder too. But since the fridge has more surface (larger door) it warms faster and thus the freezer gets colder.
Of course, the explanation about voltage is good too. Plug in a meter or 2 (i have 3)
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
