time2rollagain
Jul 23, 2024Explorer II
I would start with the electric supply you are plugged into and check for reverse polarity there.
Then check the main cord has correct polarity into the main panel.
I doubt it is the air conditioner itself or the power feeding to it is causing the issue.
- rocavanaJul 24, 2024Explorer
We're hooked up to shore power on our property, we had an electrician install a temporary metered power outlet box since we're planning on building as well in the future. Hopefully they didn't reverse anything, but I guess it's possible. I'll take a closer look at our main cord and see if I can identify any issue there, idk why it would be charging the camper exterior when just the air conditioner cord is wired in and not the other circuits though.
