road-runner
Jul 28, 2024Explorer III
If the RV exterior is "hot", you do not have a good ground connection to the RV's electrical system. There may or may not be other problems but you need to fix the ground first. The receptacle tester needs to have a good ground connection to give correct readings.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
