MFL
May 27, 2019Nomad II
Normally you can see through the vents, to see if leaves, debris, or other needs to be removed. Depending on use, and location there can be more cleaning, of cooling fins, and condenser needed. The drain pan outlets need an occasional cleaning also.
I do have to say, many will neglect these issues, until the AC no longer works.
Jerry
Jerry
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
