TomG2's avatar
TomG2
Air conditioner efficiency
I recently purchased a new travel trailer and deliberately went with a non-ducted AC this time. It is working great in 100+degree heat. My thinking was to avoid the long runs of ducts in the ceiling where the maximum heat gain is likely. Does anyone know if it actually makes a difference in efficiency? I use a small fan to spread the cool air around and aid in circulation.
  • I like having both options. We dump it to get a jump start and then switch it over. Couldn't live without the ducts with our layout. Kids bunks would be hot as well as master bedroom.
  • Ours are ducted, with a "chill grill" that can be opened. When very hot out, open both grilles and use a good fan to circulate the cool.
  • I have no doubt about the value of ducts in cooling remote areas. I am only thinking of the efficiency in cooling an open area approximately 8 X 25. I know the first air to come out of the ducts was always very warm.
  • Old-Biscuit wrote:
    I have best of both.......
    Ducted (cold air comes out farthest away from AC Unit) and a 'chill grill' which I can open and DUMP majority of discharge plenum straight down into kitchen/living area.
    Mine also and it definitely cools better in the non-ducted position.
    Ducting is less noise. Probably the ducting is leaking quite a bit into the ceiling cavity but I have not been brave enough to pull it all apart to fix it. If I remove an electrical cover plate there is cool air coming out of the wall... one guess where that comes from.
  • I have best of both.......
  • Well I have 43 years in the RV business and 38 of those as a RV technician. Still am. I was here for the non ducted and now for the majority of ducted. You do NOT state what size trailer. But, I can tell you, that Ducted is the BEST thing to have. I would NOT have a larger trailer(more than 22 foot) without ducted AC. The Cold loss is minimal. Doug
  • I would think that not having to cool the ducts, and even if well insulated,the space the ducts run through, would provide considerably more cool air to the living area.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
