SkiingSixPack
Aug 01, 2016Explorer
When the AC compressor shuts off, the air that keeps blowing is air from inside your camper. It is not air from the outside, at least if everything is sealed up correctly. Now, I know that this does not help you with your question about how to run your model so that the fan does shut off, but I just thought I'd let you know that the ACs are designed to just recycle the inside air and they do not pull in outside air.
We always run ours with the fan always on, and then control the temperature with the temp dial. Running the fan constantly helps keep the RV much cooler (air flow) and helps prevent the compressor from freezing up.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
