WVmtnhiker's avatar
WVmtnhiker
Air Conditioner not working and I am desperate
The A/C unit (Dometic) on my new Coachman Apex shut off after running for about 30 seconds. Checked circuit breaker and it is in on position. The manual talks about waiting 2 minutes before restarting the compressor, otherwise compressor will quick cycle and could result in compressor or supply overload. A/C will not restart and I was wondering if there is some sort of a switch or button that must be reset?
Thanks as always for the help,
mtnhiker
  • I would shut breaker off and back on but first turn your water heater to gas if it's on electric. Mine I found out the hard way my first year with trailer that the air and water heater overloads the electric. If that doesn't work make sure you have 110 in your trailer. One time I blew the pedestal breaker and took a while to figure it out. Anytime I'm going to use air I eather shut water heater off or turn to gas, haven't had a problem since.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
