JohnnyT
May 24, 2013Explorer II
I would be focused on the blower motor... Over the years I have had two go bad and gave the same symptoms as you describe.
You can try and see if the when you select fan only the blower motor turns. Other wise its up on the roof remove cowling and see if the fan turns freely.. Just make sure power if off to the unit...
Not that big a deal to replace if the blower motor is bad..
JohnnyT
JohnnyT
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
