Born2hunt's avatar
Born2hunt
Air conditioner problems
One of the air conditioners in my fifth wheel is acting up and I can’t afford an rv tech right now so I’m handling it on my own. I have a pretty decent electrical background so I’m not going to kill myself touching something I shouldn’t so don’t worry.
The fan and compressor switch off and on independently of each other. They’ll both turn on then one will turn off while the other is still running and vise versa then it’ll turn back on.. Sometimes the fan will kick off but the compressor is still on and humming. They’ll only stay on or off for a couple minutes at a time. The fan will also come on when I turn the breaker on with the thermostat unplugged.
I’ve already tested the capacitors and replaced one which wasn’t testing in spec but the problem persisted.
I’m hoping one of y’all can point me in the right direction of what to check or replace next. Thank you.
Also it is a Duo-Therm. Model #59136.331
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
