wa8yxm
Jul 25, 2017Explorer III
Obtain a plug in volt meter, if your RV is 50 amps make sure you plug into an outlet on teh SAME LEG (L-1 or L-2) as the A/C..
Two things other than a bad A/C can cause that
1: A thermostat set to AUTO that switches the fan from LOW to HIGH and back (or high to low and back) as the temp changes
And #1 on the suspect list is 2: Variable voltage in the campground.. I see this all the time in some places.. Fans slow down and speed up with voltage changes.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
