OldSmokey
Jul 25, 2017Explorer
BraxtonBaird1 wrote:
I thought the cap was used only for starting the blower.
no, it's for running
I would also suggest as many have that the run cap is dying or
you may have a bad fan bearing that has partially dried out and is
causing a partial seizure. the bearing becomes tight due to no lube and
then heat generated melts some remaining grease that flows and frees the bearing. this cycle repeats until final seizure.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
