wa8yxm
Jul 25, 2017Explorer III
BraxtonBaird1 wrote:
Thanks wa8yxm, I like that idea but how do I determine which plug is on the same leg as the A/C? I know for sure that when this happens the thermostat is not on Auto.
Two ways. ON a 30 amp RV, all the outlets and the A/C same leg or if plugged into 30 amps you will be close enough
ON a 50 amp RV you do it by the Cadence method
Left/right/left/right or in this case 1-2-1-2-1-2
In my Breaker box the mains are on the left and the branches out from there 1-2-1-2-1-2-1-2
On some the mains are in the middle and they may be the same as mine o r they may be 111111 mains 2222222
And then we have teh "Residential: type (Vertical rows mains at top
1 2
2 1
1 2
2 1
IS the usual configuration on those
If the A/C is a "2" look for outlets that loose power when you turn off a "2" breaker.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
