pianotuna
Aug 20, 2016Nomad III
Hi,
I added a 2nd thermostat for just the furnace. That means I can use both the roof air and furnace to provide heat.
I only have the heat strip, unfortunately, so when the day finally comes that the compressor dies I'll certainly consider upgrading to a heat pump.
For times when the heat is enough from the roof air, I replaced the cold air return with dual window fans on a thermostat--they blow into the cabinet and move a little bit of air through the duct work which keeps all the pipes "happy" in cold weather.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
