joebedford's avatar
joebedford
Nomad III
Jan 26, 2024
Solved
Air Conditioner vibration
My toy hauler was stored over the summer. When I hooked it up for snowbirding in December, the a/c's both cooled fine but both vibrated as soon as the fans started. The main a/c stopped doing it afte...
  • joebedford's avatar
    Mar 15, 2024
    I finally worked up the energy to climb onto the roof and remove the a/c shroud. Sure enough, there was a hard 3" mud nest by the hot side squirrel cage but it had fallen off the cage and was lying on the floor of the a/c. I had DW turn the unit on while I watched it and the motor was still shaking back and forth about 1/4". I concluded that there must be more stuff on the cool side fan. Sure enough I could see 3 50 cent sized blobs on the inside of the inside squirrel cage. I was able to get most of the mud out by poking a screwdriver through the fan louvres(?). There was also a 3" blob on the wood frame for the a/c. I removed all the debris and the fan is much smoother now - still a bit of vibration but for all I know that's how much it has shaked ever since the rig was new. Storage covers this summer. Anyway, problem solved.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
