pianotuna
Jul 30, 2019Nomad III
Hi CA Traveler,
Thanks for pointing that out to me.
It is an absorption fridge--so as voltage rises it uses more power, when the autoformer is doing its "thing". The recovery time is less than a second.
I can certainly repeat the test with the fridge off for start up measurements. I suppose I could run the fridge on propane. I don't see any point in having the inverter/charger off as it was drawing essentially nothing. I.E. not in load support mode, so the inverter was off.
CA Traveler wrote:
Don,
Very interesting numbers which show constant amps (12.4A) with changing voltage for the refer and A/C. If the refer is the absorption type then it uses less amps with decreasing voltage and hence the A/C uses more.
It would be interesting to see the numbers for the A/C only, all other appliances off.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
