3_tons
Jul 31, 2019Explorer III
pianotuna wrote:
One last test--which had disappointing results.
Ambient temperature 76 f
Interior of RV 81 f
Yamaha 2800 sIEB run for 2 minutes to warm up. eco switch off.
No load voltage 122.1v
turn on only air conditioner
97 volts recovering to 119.5 1101 watts
Retest with eco switch on after waiting ten minutes.
generator over load
Retest with magnum load support turned on
generator over load
Retest with autoformer
generator overload.
Not what I was expecting at all.
Don, Something seems amiss here, especially if you have the Soft-Start....Converter-charger is off?...Autoformer operable?
Be advised that I had a similar problem, and was ultimately able to correct it by resetting my ProSine to it’s factory defaults...
Even when only Standby mode (not inverting) it may passively shut off shore power from entering the coach if the Genny voltage or Hz is sub-par...Sub-par voltage could be a parameter of the programming.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
