jharrell
Aug 01, 2019Explorer
Make sure Magnum shore setting amps correct, you should have noticed it, but Magnum could be trying to charge batteries and run a/c, lowering shore amps tells the charger to back off, also tells it when load support kicks in on hybrid.
Autoform and generator really not a good combo, if gen can't provide voltage auto form pulls more current, dragging gen down even more. Gen should be throttling up to provide correct voltage and current up to its capacity otherwise something wrong with it.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
